Dear Sirs and Madams,
We installed ModusToolbox 3.0(MTB 3.0) and created a PSoC4 Empty project, but the Cy_Sislib_Delay API is Undefined and get a build error.
An error occurs even with the following simple procedure:
(1) Install ModusToolbox 3.0
(2) Select New Application in Quick Panel
(3) Select CY8CKIT-145-40XX in PSoC4 BSPs
(4) Select Empty PSoC4 App of Getting Started, don't change name, then create.
(5) Write "Cy_Syslib_delay(500);" in main.c
(6) Build Application in Quick Panel
(7) A build error occurs as below:
We cannot avoid this "undefined reference to `Cy_Syslib_Delay'" problem.
What could be the problem?
ModusToolbox General
You wrote the API function name incorrectly,It should be Cy_SysLib_Delay。
I understood that the API was misspelled.
It would be nice if ModusToolbox also had an API auto-recognition function like PSoC Creator.
thank you.
