paddyliu
Distributor - Macnica(GC)
5 comments on blog First comment on blog First like received
Dear Sir,
When I use Modus Export to Keil . When  reopen Keil  Project. The last parameter setting in Keil has lost. Why does the exported Keil project have this problem? Thanks.
使用Modus tool box 将工程文件导出到Keil,在Keil环境下进行开发,在Keil工程里添加led.h和led.c文件,保存后,关闭Keil工程文件,等重新打开Keil后,上次添加的.c和.h就消失了,似乎没有保存功能一样,同样设置的“Options for target”一些参数,等到重新再次打开Keil后,上次设置的参数没有保存住。Keil 版本V5.28. 若是重新单独新建一个Keil工程,不会出现这种无法保存住的现象。
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
1: 在不考虑添加的LED文件,单从MTB tool里面把工程导到Keil里面是否可以正常工作。
2: 你是否是参考MTB tool user guide中的导到第三方工程的方法做的?
3:     你现在用的MTB tool的版本是什么?
LinglingG_46
paddyliu
Thanks Lingling, thanks  for your support.The problem has already been solved. The reason is that I open the .cpdsc file every time instead of opening .uvprojx.
