xlu
10 sign-ins 5 sign-ins First reply posted
I have installed Modus Toolbox , and uninstall and install again in different location, after installation, I try to import an object by file->new->Modus toolbox App, it come following info:
Log file(s) for this session are stored at: C:\Users\xlu\AppData\Local\Temp\Logs7924986194417700111
Unable to find ModusToolbox executables:
Unable to execute project creator command.
For the first installation, we can run this  function smoothly. but after uninstall and install again it cannot run. we also try to reinstall again in the same location as the first installation, but failed. Could you please help me out
Rakshith
Hi @xlu
Can you please follow the steps mentioned in this KBA and let me know if it helps? -  Tools Directory not found in ModusToolbox 2.x – KBA231392
Thanks and Regards,
Rakshith M B
Rakshith
Hi @xlu
Thanks and Regards,
Rakshith M B
