I have following built error since today. I can not build example projects:
C:/Users/phili/ModusToolbox/tools_2.3/make/startex.mk:380: *** Build support for the target device not found. Run "make getlibs" to ensure all required build and code dependencies are present.. Stop.
I have tried it on two different systems (Laptop and PC). I also ran the getlibs.mk from the make folder with the modus-shell.
What could be the problem and how can I fix this?
Thanks and best regards,
Phil
ModusToolbox General
Hello! The error was caused by incorrect XML entry introduced in the BSP manifest last week.
I fixed the BSP manifest, the ModusToolbox projects can be created with no error: https://github.com/Infineon/mtb-bsp-manifest/commit/1d67adcd42a2eb092362021b0327b4f780e34c16
Sorry about the inconvenience caused by this issue, the ModusToolbox development team will figure out how to prevent incorrect XML manifest edits from happening in the future.
I have the same problem
Hello @PhilD ,
I am able to reproduce this error. It is due to a missing XML tag in one of our manifest files. I have notified the software team and it will be fixed today. I will update this thread once fixed. Sorry for the inconvenience caused.
Currently, the workaround is to open Library Manager from ModusToolbox/tools_2.x directory and update the libraries manually. Here are the steps:
1) Open Library Manager
2) Point to the Application Directory (it will be available in the workspace even though the application failed)
3) Under Libraries, select the following libraries:
- core-lib
- core-make
- capsense
- mtb-hal-cat1
- mtb-pdl-cat1
- psoccm0p
- recipe-make-cat1a
4) Click Update. Once the libraries are updated, click Close.
5) Open ModusToolbox IDE > File > Import > ModusToolbox > ModusToolbox Application Import.
6) Point to the project location and click Finish.
You should now be able to use the application. Let me know if this works for you 🙂
Dheeraj
Thank you @VMED , for reply.
I have not even solved the problem.
I have uninstalled and reinstalled Modustoolbox 2.3.1. I have created a new workspace, too. And the result was the same. 😞
With the most recent update, now everything is working correctly. Including my previous projects and workspaces that I had previously backed up. 😎👍
