Dear Sirs and Madams,
We started using Modus Tool Box (MTB).
I would like to use XMC1100, however I can't find the BSP of "KIT_XMC_2GO_XMC1100_V1"
I found a similar question in this community.
From the answer to that question, I understand that I need to create a custom BSP from "xxxx-GENERIC".
Therefore, I created a new project from "XMC-GENERIC".
I have created a project for XMC1400-Q064x0200, However, the change to the XMC1100 implemented in the demo kit cannot be done well.
I've also confirm for MTB user manual, but don't have any documentation with more details on device changes?
Or are there any plans to release the BSP of "KIT_XMC_2GO_XMC1100_V1"?
KIT_XMC_2GO_XMC1100_V1 demo kit URL
https://www.infineon.com/cms/jp/product/evaluation-boards/kit_xmc_2go_xmc1100_v1/
Currently we do not have the support for XMC1100 BSP. The BSP support for XMC1100_Bootkit is happening in background and will be released in the near future. The support for KIT_XMC_2GO_XMC1100_V1 kit we are still working on.
Vasanth
Vasanth
Vasanth-san,
Thank you for your reply.
I understand that XMC11000 BSP is not supported.
If that happens, I think it will be a procedure to change the device using Modus-Shell.
Do you have a manual for Modus-Shell?
Is Modus-Shell the same as MS DOS?
Hi Masashi san,
You should be able to change it by changing Target in the Makefile. Once the extended device support are out in MTB this should be easier. See this link regarding CLI.
https://www.cypress.com/file/492931/download
Vasanth
