Frank_vec
Distributor - Zenitron(GC)
50 replies posted First like received First comment on blog
我看abstraction-rtos支持3个系统,FreeRTOS、RTX、ThreadX,目前示例里面只有FreeRTOS,其他的两个没有,包括库里面也没有,这个有没有示例;我想要 RTX、ThreadX的modus参考例程
I think abstraction rtos supports three systems, FreeRTOS, RTX and ThreadX. At present, there are only FreeRTOS in the examples, and the other two do not, including the library. Is there an example of this one; I want the modus reference routine of RTX and ThreadX
YuZh
100 replies posted 10 likes received 50 sign-ins
Hi:
抱歉,暂时zephyr是无法通过modus来开发的,相=想必你也知道Zephyr OS是一套类似于Linux开发的实时操作系统,所以他比较依赖命令,但是他也有对应的IDE,但我估计不是太好用,当前我的Zephyr OS是基于Win10操作系统作为开发环境,用CMD或者powershell来进行命令行的开发。所以总之你如果要开发Zephyr OS,你第一件事情就是要把整个环境搭建好,Zephyr OS 官网有相关教程,你可以参考。
zhichao
YuZh
Hi:
目前官方只有freeRTOS,你说的后面两种貌似我们没有支持,目前,我们倒是在支持RT-Thread和Zephyr OS,只是还没有发布。
zhichao
Frank_vec
“我们倒是在支持RT-Thread和Zephyr OS,只是还没有发布。”
您好我想知道,大约何时可以发布支持 Zephyr OS 的 功能的modus版本呀 ?
不胜感激
YuZh
Hi:
都在推进中,具体时间不好评估,我现在不知道您的应用场景和需求,您可以说说您的需求,我可以帮您分析那款操作系统更适合您,您是从哪个角度想要使用Zephyr OS,或者您事项对比几个操作系统那几个参数?
zhichao
Frank_vec
Dear manager
  好的,还有,modus是怎么开发zephyr软件的,是支持的吗 ?我的psoc6想带Zephyr系统,想用modus开发
YuZh
Hi:
zhichao
Frank_vec
非常感谢您的回答
umamahesh
How to compile FreeRTOS using Modus Toolbox, any procedure to refer. Where to clone free rtos  with bsp for aurix tc735, please help me on this regard
YuZh
Hi:
Please refer to this web site: https://community.infineon.com/t5/AURIX/FreeRTOS-for-AURIX-TC375/td-p/381648
By the way, please create a new post if you want to ask new question. Maybe it's better to search next time.
zhichao
umamahesh
It was posted by me as I am looking for solution. Hope you read the post.
YuZh
Hi:
My colleague has answered your question. Because I 'm just responsible for PSOC6. So I could not give you the solution. Please refer to that post.
zhichao
