We are using CY8CKIT-062S2-43012 and using "Hello World" code example, everything seems to work. But when I try to open the BSP API Reference Manual within the MTB IDE, it gives me error "File not found"
Documentation->CY8CKIT-062S2-43012 BSP->More Information->BSP API Reference Manual
It supposes to be in the folder file:///C:/Users/<user>/mtw/Hello_World/libs/TARGET_CY8CKIT-062S2-43012/docs/html/modules.html
Other documents like HAL and PDL manual are OK. We are using MTB version 2.4.0
Anybody knows how to fix the issue? I am pretty new to Cypress SoC and MTB, any comments/suggestions are appreciated!
You can open it directly in the folder with a browser!
Thanks. I understand, I can see the folder C:/Users/<user>/mtw/Hello_World/libs/TARGET_CY8CKIT-062S2-43012/docs/html/ but what is missing is the modules.html file. Is there a setting to enable/disable the file generation?
