Memory analyze with ModusToolbox
rymi_3859196
First question asked
Hi guys.
I am working on PSoC 6 Wi-Fi BT Prototyping KitP
and I am wondering how I can analyze the memory size of the heap when debugging.
I am using the latest Modus Toolbox on macOS.
Takashi_M
1000 replies posted 500 solutions authored 750 replies posted
You can check memory size as following.
This uses the Expression view in the Debugger and shows the size (in bytes) of dividerType and dividerNum in this case (example).
Takashi_M
Dear Author,
Apologize for late response, but a little bit more time is needed.
Will update this thread as soon as possible, if some confirmation is done.
thank you.
Takashi_M
