[Linux] projecet-creator - Incompatible version of OpenSSL
chex_4364951
First question asked First reply posted
Hello!
I have issues with the Linux version of the ModusToolbox, especially with the Project Creator tool.
It can't fetch the the BSPs but the issue is not the same as already reported here with the workaround: A workaround to solve "Some boards and apps may be missing" in ModusToolbox
My problem is that the Project Creator can't even try to fetch the file because it seems that the OpenSSL version on my system isn't compatible:
Getting manifest...
qt.network.ssl: QSslSocket: cannot resolve CRYPTO_num_locks
qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_id_callback
qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_locking_callback
qt.network.ssl: QSslSocket: cannot resolve ERR_free_strings
qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_cleanup
qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_init
qt.network.ssl: QSslSocket: cannot resolve sk_new_null
qt.network.ssl: QSslSocket: cannot resolve sk_push
qt.network.ssl: QSslSocket: cannot resolve sk_free
qt.network.ssl: QSslSocket: cannot resolve sk_num
qt.network.ssl: QSslSocket: cannot resolve sk_pop_free
qt.network.ssl: QSslSocket: cannot resolve sk_value
qt.network.ssl: QSslSocket: cannot resolve SSL_library_init
qt.network.ssl: QSslSocket: cannot resolve SSL_load_error_strings
qt.network.ssl: QSslSocket: cannot resolve SSL_get_ex_new_index
qt.network.ssl: QSslSocket: cannot resolve SSLv3_client_method
qt.network.ssl: QSslSocket: cannot resolve SSLv23_client_method
qt.network.ssl: QSslSocket: cannot resolve SSLv3_server_method
qt.network.ssl: QSslSocket: cannot resolve SSLv23_server_method
qt.network.ssl: QSslSocket: cannot resolve X509_STORE_CTX_get_chain
qt.network.ssl: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_noconf
qt.network.ssl: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_conf
qt.network.ssl: QSslSocket: cannot resolve SSLeay
qt.network.ssl: Incompatible version of OpenSSL
qt.network.ssl: QSslSocket::connectToHostEncrypted: TLS initialization failed
Processing super-manifest https://github.com/cypresssemiconductorco/mtb-super-manifest/raw/v2.X/mtb-super-manifest.xml...
Download of https://github.com/cypresssemiconductorco/mtb-super-manifest/raw/v2.X/mtb-super-manifest.xml failed: TLS initialization failed
Failed to get the information.
So, what version of OpenSSL is required?
My system is: Ubuntu 19.10
Christian
chex_4364951
Okay... figured it out.
The qt5 library you guys are using doesn't support newer libopenssl versions...
Had to compile 1.0.2k as described here: Re: ModusToolbox 2.0 fails to load example project on linux install
To get it running!
mkdir -p ~/ModusToolbox/libssl/build
cd ~/ModusToolbox/libssl
wget https://github.com/openssl/openssl/archive/OpenSSL_1_0_2k.tar.gzenssl/archive/OpenSSL_1_0_2k.tar.gz
tar -xvf OpenSSL_1_0_2k.tar.gz
cd openssl-OpenSSL_1_0_2k/
./config --prefix=/home/<user>/ModusTollbox/libssl/ zlib shared
make
make install
Then start start the project-creator manually like this:
LD_LIBRARY_PATH=/home/<user>/ModusToolbox/openssl/build/lib/ ./<path_to_your_toolbox>/tools_2.1/project-creator
Also possible to get it work in the IDE, just start the IDE from the terminal and export LD_LIBRARY_PATH before:
export LD_LIBRARY_PATH=/home/<user>/ModusToolbox/openssl/build/lib/
./<path_to_your_toolbox>/ide_2.1/eclipse/ModusToolbox
Please fix this issue in the next version!
Christian
chex_4364951
To get it running!
make
make install
Christian
Hello Christian,
Yes, you are right. I have passed this enhancement request to our software development team who will evaluate your query.
Thank you for your interest in Cypress products.
Dheeraj
