ModusToolbox™ General
I tried to program my KitProg (PSoC® 6 Wifi-BT) using the PioneerKitApp, and I get a message:
Error: *********************************************************************************************
Error: * KitProg firmware is out of date, please update to the latest version using fw-loader tool *
Error: No Valid JTAG Interface Configured.
Where do I find the fw-loader tool and latest firmware?
Enrico
mattl_01
Hey Enrico,
Sorry about that.  Everything you need is right there in the installation.
See Chapter 7 of the User Guide, starting on page 54. The first thing
you want to see if your kit has kitprog2 instead of kitprog3. It probably
does.
Assuming you are on windows, open a  cmd window. Then, run the command
fwloader --device-list
Yes, that is two dashes "--"
If it says something like Kitprog2 blah blah blah then, run the command
fwloader --update-kp3
Let me know if that doesn't work. By the way, fw-loader is in $CYSDK/tools/fw-loader-1.0/bin.
You can probably do all this without even opening up the User Guide.
If you want to then use that kit with PSoC Creator, you need to first run
fwloader --update-kp2
to go back down to kp2.  You wouldn't have to do this after the next release of Creator though.
There is one other issue regarding SW3 on the board, but try this first. It should fix you up.
--Matt
mattl_01
Hey Enrico,
does.
--Matt
I'm on a Mac.  I can see that it is mounted as KitProg2 on the desktop.
Here are the commands I used through Terminal:
/Applications/ModusToolbox_1.0/tools/fw-loader-1.0/bin/fw-loader --device-list
Result:
Cypress Firmware Updater, Version: 1.0.0.505
(C) Copyright 2018 by Cypress Semiconductor
All Rights Reserved
Info: Start API initialization
Info: Connected - KitProg2 CMSIS-DAP HID-XXXXXXXXXXXXXXXX <- to mask my HID
Info: Hardware initialization complete (465 ms)
No connected supported devices
Tried the --update-kp3 command and got the same result.  Doesn't seem to recognize the hardware.
Enrico
mattl_01
OK, give me a second. I don't want you to push that SW3 switch until I check the documentation one more time.
mattl_01
OK, first you need to get your kit out of "CMSIS-DAP HID" mode.  To do this, you press SW3 on your board.
SW3 is near the left-side, a little less than halfway up (I have my board oriented where the USB part connected
to the PSoC 5 used for programming is on the left-hand side and the CapSense area is on the bottom right).
After pressing that button, LED 2, right below the SW3, should go from OFF (which I hope it is now) to ON.
Now, you should be able to run fwloader --update-kp3
I think we need a blog post on this.  There is information in the User Guide, but that is a little inaccessible
and doesn't have enough on messages you might see.
Ok.  Here are my results once having used SW3 so that the LED is on.  My Mac (MacBook Pro 2013) indicated that the device was no longer connected.  I think this worked with your assistance.  Agree that the posts need to be a little more step by step for noobs like me. : )
Ran the following command in Terminal:
Result:
All Rights Reserved
Info: Connected - KitProg2-XXXXXXXXXXXXXXXX
Info: Hardware initialization complete (464 ms)
Connected supported devices:
  1: KitProg2-XXXXXXXXXXXXXXXX FW Version 1.5.0
It did recognize the device!
Ran the following command to update the firmware:
/Applications/ModusToolbox_1.0/tools/fw-loader-1.0/bin/fw-loader --update-kp3
Result:
All Rights Reserved
Info: Hardware initialization complete (469 ms)
Device 'KitProg2-XXXXXXXXXXXXXXXX' opened successfully
Info: Kit FW is 'KitProg2' ver. 1.05 b000. Upgrade file is 'KitProg3' ver. 1.01 b158
Info: Disconnected - KitProg2-XXXXXXXXXXXXXXXX
Info: Connected - KitProg Bootloader-XXXXXXXXXXXXXXXX
Info: Bootloader Version: Major 1, Minor 1, Build 40
Info: FW Upgrade to version: 1.01 b158
Info: Bootloading ...
Info: Verifying ...
Info: FW Upgrade completed
Info: Connected - KitProg3 CMSIS-DAP BULK-XXXXXXXXXXXXXXXX
FW update completed successfully
Info: Disconnected - KitProg Bootloader-XXXXXXXXXXXXXXXX
I went back to Modus and tried to build and it appears to have completed successfully.
These were the last few lines in the build status window:
wrote 18432 bytes from file /Users/edepaolis/mtw/PioneerKitApp_mainapp/Debug/PioneerKitApp_mainapp_final.elf in 0.813853s (22.117 KiB/s)
** Programming Finished **
** Program operation completed successfully **
srst_only separate srst_gates_jtag srst_open_drain connect_deassert_srst
Info : SWD DPIDR 0x6ba02477
shutdown command invoked
I'll have to try the blinky app and see if that works as I am still learning all this stuff at this point and am not sure what the basic program I loaded is supposed to show.  I'll continue the testing tomorrow.  Thank you for assisting this far.
Enrico
I was able to load the Blinky app to the board so it appears to be working.  Thanks again for the assistance!
Enrico
mattl_01
Excellent, sorry for the difficulty.
