I am always failing in using the MiniPro4 burning WLC1115 program and reporting the following error:
Error: kitprog3: failed to acquire the device
Error: Error connecting DP: cannot read IDR
Error executing event examine-end on target psoc4.mem_ap:
/ModusToolbox/tools_3.0/openocd/bin/../scripts/target/psoc4.cfg:169: Error:
in procedure 'program'
at file "/ModusToolbox/tools_3.0/openocd/bin/../scripts/target/psoc4.cfg", line 169
Warn : target psoc4.cpu examination failed
Error: [psoc4.cpu] Target not examined, reset NOT asserted!
** Program operation failed **
srst_only separate srst_gates_jtag srst_open_drain connect_deassert_srst
Warn :
* KitProg firmware is out of date, please update to the latest version (2.40.1241)
* using fw-loader tool which can be found in the following folder
ModusToolbox/tools_3.0/fw-loader
Hi Lance,
DAPLink is not a correct mode for programming WLC1115. Can you please refer to the command line in chapter2.5 of fw-loader User Guide, to switch to BULK mode and try again?
Thanks,Fred
Hi Lance,
Possible for you to update the KitProg firmware from KP2 to KP3 firstly and then try?
You can refer to the fw-loader User Guide to make the update - C:\Infineon\Tools\ModusToolbox\tools_3.0\fw-loader\docs
Hi ,
After I update, there is a new error when burning:
Error: It looks like your debug probe is in DAPLink mode. Please switch to KitProg3 mode or use CMSIS-DAP driver instead.
Error: No Valid JTAG Interface Configured.
Hi Lance,
Thanks,Fred
