ModusToolbox™ General Forum Discussions
baga_4725781
...after dealing with with not installing ModusToolbox in a default location (had to edit makefile..)
Now, I cannot get it to execute.
I can see the board in the Windows device manager:  KitProg3 CMSIS-DAP
I get this popup. Issue is: There is no Debugger tab!
I have set the debugger path to the .hex file. (Also tried the .elf).
I have tried following the documentation on build/execute. I have been doing embedded systems for 35 years. This is one of the most frustrating tools I have ever used that is supposed to be "easy".
Modus Toolset 2.1
PWM_Square_Wave
Board PSoc 6 Wifi BT prototype board
chip CY8C624ABZI-D44ES
CPU board CY8CMOD-062-4343W
I am missing something obvious, but I have tried what I can.
Thanks!
I started from scratch.
I didn't see exactly what you showed (different screen) but it works!.
I knew I was missing one little detail.
I did the sequence:
0. power cycle board (unplug/plug)
1. start a new project
2. new build
3. launch for PWM program (KitProg3) - worked great.
Much thanks! .. yours … bandit
DheerajK_81
Sorry about the inconvenience caused. We will look into how this can be improved.
In the Quick Panel window, you should see the Generate Launches option.
Once you click on this, you should see four config options generated for programming and debugging as shown above.
I think you are facing this error because you manually tried to create the configs and do not have the required options in the Config options tab of Debugger as shown below:
Please delete the config options you crated and use the Generate Launches option. It will create the configs and fill in all the fields automatically for you.
Let me know if you face any difficulties
Dheeraj
I did the sequence:
2. new build
(blush) I just found this sequence on https://www.cypress.com/file/457891/download
CY8CPROTO-062-4343WPSoC 6 Wi-Fi BT Prototyping Kit Guide  Doc. # 002-25200 Rev. *A
page 24. Helps to read the documentation :^)
Humbled ... bandit
