I'm using ModusToolbox with PSoC6.
I know it is possible to launch the debugger from ModusToolbox IDE, but I need to use it from command line.
Any one know which settings should I use?
What I did so far:
I have 3 terminals:
Terminal A)
The only thing that I did was: `make debug`
Terminal B)
I connect with OpenOCD using:
```telnet 127.1 4444
init; reset init
Terminal C)
I connect using gdb by doing:
${CY_TOOLS_PATHS}/gcc/bin/arm-none-eabi-gdb lego-psoc6-app.elf
(gdb) break main
(gdb) target extended-remote :3333
Remote debugging using :3333
0x0000012a in ?? ()
(gdb) cont
And it gets stuck in 0x0000012a
I never reaches `main`
Any idea? Thanks!
ModusToolbox General
Have you tried to follow section 2.7 of the ModusToolbox User Guide, especially 2.7.3?
yes. I mentioned that on my original comment. I doing "make debug", then I'm attaching GDB... but I cannot debug it. Execution is stuck at 0x0000012a
Please provide the IDE screenshots and other relevant data so we could better investigate the problem.
Just to make it clear, debugging from the IDE works Ok.
I'm looking for detailed instructions regarding how to debug from command line.
I can provide an screenshot of the command line, but it includes exactly what I posted in my first comment.
Thanks!
