ModusToolbox™ General Forum Discussions
gykim
25 sign-ins 10 replies posted 10 sign-ins
Hi all.
I have a simple question.
How to get build date and time?
I want to display it as debug message in my application.
My environments are...
Modus toolbox ver : 2.4
cyw20819A1
Rakesh_BG
Moderator 10 likes received 25 solutions authored 50 replies posted
Hi @gykim ,
You can add the below line to get the build date and time in console.
printf ("Date : %s and Time %s.\n",__DATE__, __TIME__);
__DATE__
This macro expands to a string constant that describes the date on which the preprocessor is being run. The string constant contains eleven characters and looks like "Feb 12 1996". If the day of the month is less than 10, it is padded with a space on the left.
If GCC cannot determine the current date, it will emit a warning message (once per compilation) and __DATE__ will expand to "??? ?? ????".
__TIME__
This macro expands to a string constant that describes the time at which the preprocessor is being run. The string constant contains eight characters and looks like "23:59:01".
If GCC cannot determine the current time, it will emit a warning message (once per compilation) and __TIME__ will expand to "??:??:??".
Rakesh B  G
Rakesh_BG
Hi @gykim ,
__DATE__
__TIME__
Rakesh B  G
gykim
Thanks Rakesh B G.
It works well.
