Dec 16, 2022
02:37 AM
Dec 16, 2022
02:37 AM
i want to use CY8C4024LQI-S401 and i tried to fix the file bsp.mk name but it doesn't work when build gives error. is only run whith CY8C4045AZI-S41
02:48 PM
Dec 19, 2022
02:48 PM
Use the BSP Assistant to change devices in the BSP. This should take care of all the necessary file changes.
EDIT: I just tried this, and there are several pin errors that need to be corrected in the Device Configurator. It looks pretty straight forward to correct, but I don't have the hardware to confirm.
