ModusToolbox™ General Forum Discussions
TakMune
First reply posted 10 questions asked 25 sign-ins
I’m trying to connect the CSBSYSKIT-DEV-01 to own MQTT-TLS broker based on sample application mtb-example-optiga-mqtt-client.
How can I output the logs from the MbedTLS library through UART?
Below options are defined in the makefile.
MBEDTLSFLAGS = MBEDTLS_USER_CONFIG_FILE='"mbedtls_user_config.h"' CY_CRYPTO_HAL_DISABLE ENABLE_SECURE_SOCKETS_LOGS
tayo
250 sign-ins 50 replies posted 25 replies posted
Hello
Could you try to change the definition of log_level defined in <project name>libs\secure-sockets\source\COMPONENT_MBEDTLS\cy_tls.c?
#define MBEDTLS_VERBOSE <log_level>
tayo
Hello
