I am using the BLE063 kit which comes with a pre-configured UART channel at P5_0 and P5_1. I would like to know how can I create another UART channel using another set of GPIO. Thanks.
I have shared a document below you can go to page number 15 and follow the steps which are mentioned there.
https://www.cypress.com/file/495071/download
You can go to the device configurator in Modus Toolbox 2.1 > There are 9 scb blocks and you can configure 2 scbs as Uart do the necessary settings by assigning the pins save it and close the window.
You can later build your project and test it.
Please let us know if this helps you.
Alakananda
Alakananda
