AnyCloud_BLE_Multi_Beacon not working with CY8CPROTO-062-4343W as downloaded using "New Application" in "Quick Panel".
Although, CY8CPROTO-062-4343W is not listed as one of the supported BSPs in the README.md file, the project is allowed under MTB 2.4 as a 'valid' MTB BSP.
Note: Using MTB 2.4.
Note: It compiles and programs the BSP without error.
Here is the Terminal output of the Debug port info.
***********AnyCloud Example***********
****Multi Beacon Application Start****
Bluetooth Stack Initialization Successful
Bluetooth Enabled
Local Bluetooth Address: 43:43:A1:12:1F:AC
Multiple ADV started.
Use a scanner to scan for ADV packets.
Multi ADV Set Data Event Status: FAILED
Multi ADV Set Param Event Status: FAILED
Multi ADV Start Event Status: FAILED
I suspect that the code example has not been updated with changes needed for MTB 2.4.
Help would be appreciated.
Hi @Len_CONSULTRON ,
It looks like the support for multi advertisements has been removed for 4343W controller. That is why this CE is failing for this BSP. I can confirm the same from the HCI logs as well as from the multi_adv_resp_status in BTM_MULTI_ADVERT_RESP_EVENT event.
Bragadeesh
Bragadeesh
Bragadeesh,
Thanks for looking into it.
If multi-advertisements are removed, they're removed.
Suggestion: You may want to remove this CY8CPROTO-062-4343W for this Application so that "New Application" will not configure it.
I agree, we have let our internal team know to update the manifests correctly.
Bragadeesh
