LiLe_3234306
25 replies posted First comment on KBA 50 sign-ins
By reference - ModusToolbox 2.0 Installation with Spaces in User Home Directory – KBA229345,
I tried to install ModusToolbox 2.0 and "wiced_bt_sdk" with my laptop and it has spaces in my user home direcotry. However, there is error like below while installation wiced_btsdk.
I followed procedures in KBA229345 exactly but error happened. Also, I used same folder name as the document.
For your information, I attached my test environment and test procedure step by step. Please refer to attached file.
Could you help to resolve this issue?
2020/02/18 15:01:46 DEBUG: ==============================================================================
2020/02/18 15:01:46 DEBUG: = Importing libraries =
2020/02/18 15:01:46 DEBUG: /bin/bash: -c: line 0: unexpected EOF while looking for matching `"'
2020/02/18 15:01:46 DEBUG: /bin/bash: -c: line 1: syntax error: unexpected end of file
2020/02/18 15:01:46 DEBUG: make: *** Error 1
2020/02/18 15:01:46 DEBUG: "make getlibs" failed.
Liam
Rakshith
Hi LiLe_3234306​,
Can you please try the steps mentioned in this KBA and let me know if it helps - ‘Make Getlibs’ Command Fails with a Syntax Error in ModusToolbox - KBA229440
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi LiLe_3234306​,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Hi RakshithM_16
It wored fine. As mentioned in the KBA229440, my error was caused double quotation(") in my system path.
Liam
