Document error
Panometric
100 sign-ins 100 replies posted 10 solutions authored
In  MTB 2.4 UG: 002-29893 Rev. *K https://www.cypress.com/file/524186/download
5.3 has a link https://www.cypress.com/ModusToolboxCreateCustomBSP
that in 2.2 says "make import_deps IMPORT_PATH=TARGET_CUSTOM_BSP_NAME"
BUT, MTB 2.4 Release notes: https://www.cypress.com/file/524836/download
1.11 Improved custom BSP process
We have updated the implementation of .mtbx files to provide better custom BSP support. Details for creating a
custom BSP are provided in the ModusToolbox™ user guide. The main difference is that the make
import_deps command is obsolete and no longer required. There is no issue with backward compatibility
with previous releases.
Which is correct?
It looks like perhaps https://www.cypress.com/ModusToolboxCreateCustomBSP has not been updated for 2.4?
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi @Panometric
You are right. In ModusToolbox 2.4 you do not need to run make import_deps. Thank you for pointing this out. I will create an internal ticket for the document to be updated.
Thanks and Regards,
Rakshith M B
Rakshith
Hi @Panometric
Thanks and Regards,
Rakshith M B
