Hi!
I don't know if I can create a completely blank project in modustoolbox, to be able to configure my own smartphone bluetooth communication, or can I just configure based on the projects that the developer given earlier!
Thank you.
Hi @Communication :
I suggest you select a code example and modify your custom code based on the project.
It's more convenient for you to develop your custom project.
Colin
Hi @Communication :
Colin
Thank you for replying to me!
Since I'm just starting to learn about it, when using the templates I don't know where I should fix it. I tried to fix many of the examples as you said but all failed, they appeared a lot of errors, for me it was a pretty big problem.
Thank you!
Hi @Communication :
I suggest you read the documents to help you learn about the IDE of MTB and code example architect.
OTOH, any problem or question you have you can ask us for help in this community.
Colin
Thank you for replying!
I wonder if MTB hello_sensor is a normal bluetooth communication program between kit and device or is this MTB a program that reads sensors and transmits values via bluetooth.
Thank you!
Hi @Communication :
Yes, you can refer to "hello_sensor" for this function.
You can find README in each project, and it will inform you about the project information.
Colin
Thanks!
