ChTa_4684556
Hello I'm a begineer in this. I have tried multiple settings but it still won't run properly. The Cypress still treating uint32_t as 'type cannot be resolved'. Although the code does run but still cant run the demo well. Any help please?
WLAN Firmware    : wl0: Sep  5 2019 23:24:33 version 7.45.98.92 (r722362 CY) FWID 01-f7128517
WLAN CLM         : API: 12.2 Data: 9.10.39 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2019-09-05 23:10:00
WHD VERSION      : v1.70.0 : v1.70.0 : GCC 7.2 : 2019-12-02 04:14:53 -0600
.1 5038 [Tmr Svc] Wi-Fi Connected to AP. Creating tasks which use network...
2 5038 [Tmr Svc] IP Address acquired 172.24.172.118
3 6733 [Tmr Svc] Write certificate...
4 7275 [iot_threa] [INFO ][DEMO][lu] ---------STARTING DEMO---------
5 7277 [iot_threa] [INFO ][INIT][lu] SDK successfully initialized.
.6 12027 [iot_threa] [INFO ][DEMO][lu] Successfully initialized the demo. Network type for the demo:7 12027 [iot_threa] [INFO ][MQTT][lu] MQTT library successfully initialized.
8 12027 [iot_threa] [INFO ][DEMO][lu] MQTT demo client identifier is Cypress (length 7).
.9 17097 [iot_threa] [INFO ][MQTT][lu] Establishing new MQTT connection.
10 17099 [iot_threa] [INFO ][MQTT][lu] Anonymous metrics (SDK language, SDK version) will be provid11 17100 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, CONNECT operation 0x800c168) Wai.12 22100 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, CONNECT operation 0x800c168) Wai13 22100 [iot_threa] [ERROR][MQTT][lu] Failed to establish new MQTT connection, error TIMEOUT.
14 22101 [iot_threa] [INFO ][MQTT][lu] Network connection closed on error.
15 22401 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) Network connection destroyed.
16 22401 [iot_threa] [ERROR][DEMO][lu] MQTT CONNECT returned error TIMEOUT.
17 22401 [iot_threa] [INFO ][MQTT][lu] MQTT library cleanup done.
18 22401 [iot_threa] [ERROR][DEMO][lu] Error running demo.
19 22401 [iot_threa] [INFO ][INIT][lu] SDK cleanup done.
20 22401 [iot_threa] [INFO ][DEMO][lu] -------DEMO FINISHED-------
Hi ChTa_4684556​,
Can you let me know from where you have downloaded the aws_demo project? Please confirm that you have downloaded the demo project from the Cypress git repo.
You can refer to Lesson 4 AFR Hello World of Alan Hawse's Amazon FreeRTOS 101 video tutorials for setting up things in the AWS side.
Things to be changed in the aws_demos project after importing the project -
  • #define clientcredentialWIFI_SSID
  • #define clientcredentialWIFI_PASSWORD
  • #define clientcredentialWIFI_SECURITY
  • #define clientcredentialMQTT_BROKER_ENDPOINT
  • #define clientcredentialIOT_THING_NAME
  • aws_clientcredential_keys.h (CertificateConfigurator can be used to generate this file)
Here is my log -
Also, please let me know how you have imported the project into the ModusToolbox workspace.
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
LiDo_2439176
First question asked 50 replies posted 50 sign-ins
Hello chta_4684556​,
Have you activated the certificate attached to your thing ?
Liviu
Yes, in fact I have created both cerfiticate and activated but it returned same result.Untitled.png
AWS IOT Console did register some connection from the thing
Did you enter * in the Resource ARN field from Policies ?
Yes, the star, * behind the <endpoint> is there. If I remove it, then it won't save.
Is it required that policy's name to be same as thing's name?
EDIT: This is the policy configuration with account id removed partially
  "Version": "2012-10-17",
  "Statement": [
  "Effect": "Allow",
  "Action": "iot:Connect",
  "Resource": "arn:aws:iot:<us-east-2>:<746525>:*"
  "Effect": "Allow",
  "Action": "iot:Publish",
  "Effect": "Allow",
  "Action": "iot:Subscribe",
  "Effect": "Allow",
  "Action": "iot:Receive",
Update, tried creating a policy with the name same as thing's. Still the same error.
EDIT:
WLAN CLM         : API: 12.2 Data: 9.10.39 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2019-09-05 23:10        :00
1 3510 [Tmr Svc] Wi-Fi Connected to AP. Creating tasks which use network...
2 3510 [Tmr Svc] IP Address acquired 172.24.172.118
3 5219 [Tmr Svc] Write certificate...
4 5761 [iot_threa] [INFO ][DEMO][lu] ---------STARTING DEMO---------
.5 5763 [iot_threa] [INFO ][INIT][lu] SDK successfully initialized.
6 10531 [iot_threa] [INFO ][DEMO][lu] Successfully initialized the demo. Network type for the demo:7 105        31 [iot_threa] [INFO ][MQTT][lu] MQTT library successfully initialized.
8 10531 [iot_threa] [INFO ][DEMO][lu] MQTT demo client identifier is Cypress (length 7).
.9 15578 [iot_threa] [INFO ][MQTT][lu] Establishing new MQTT connection.
10 15580 [iot_threa] [INFO ][MQTT][lu] Anonymous metrics (SDK language, SDK version) will be provid11 15        581 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012708, CONNECT operation 0x8012820) Wai.12 20581        [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012708, CONNECT operation 0x8012820) Wai13 20581 [iot_        threa] [ERROR][MQTT][lu] Failed to establish new MQTT connection, error TIMEOUT.
14 20582 [iot_threa] [INFO ][MQTT][lu] Network connection closed on error.
.15 20882 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012708) Network connection destroyed.
16 20882 [iot_threa] [ERROR][DEMO][lu] MQTT CONNECT returned error TIMEOUT.
17 20882 [iot_threa] [INFO ][MQTT][lu] MQTT library cleanup done.
18 20882 [iot_threa] [ERROR][DEMO][lu] Error running demo.
19 20882 [iot_threa] [INFO ][INIT][lu] SDK cleanup done.
20 20882 [iot_threa] [INFO ][DEMO][lu] -------DEMO FINISHED-------
Hi ChTa_4684556​,
Here is my log -
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Hello Mr Rakshith, thanks for responding to my issue.
I have been following this guide for setting up: https://www.element14.com/community/community/design-challenges/connected-cloud-challenge-with-cypre...
The way I import to ModusToolbox, is by Import existing project through folder, I import all 3 folders under /projects/<board-name>
I have edited the required files through notepad++ in /include folder
Hi ChTa_4684556​,
Thank you for your response.
I think you meant the following directory - <afr_directory>/projects/cypress/<board_name>/mtb/aws_demos/
Also can you please let me know what you mean by 'all 3 folders'. I see that there is only one example - aws_demos in CY8CKIT_062_WIFI_BT folder and two (aws_demos and ota) in CY8CPROTO_062_4343W folder.
Again I think you are talking about the <afr_directory>/demos/include folder.
Can you replace the Resource ARN with just * ? If you are editing using the json file then replace "Resource": "arn:aws:iot:<us-east-2>:<746525>:*" with just "Resource": "*"
Please let me know if the video tutorials in my previous comment or the above step helped with your issue.
If not please attach an archive of the entire <afr_directory>. I will try it out at my end and try to figure out the issue.
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Hello Mr Rakshith, thanks for your response
Sorry, my bad. I do import from <afr_directory>/projects/cypress/CY8CPROTO_062_4343W/mtb/ and imported aws_demos, CY8CPROTO_062_4343W and ota. The same error occured when I imported from <afr_directory>/projects/cypress/CY8CPROTO_062_4343W/mtb/aws_demos/, with only aws_demos imported.
I have found the problem, thanks to the video you posted. It turns out I forgot to attach a policy to the thing which in turn creates error. Thank you very much for your help!
WLAN Firmware    : wl0: Sep  5 2019 23:24:33 version 7.45.98.92 (r722362 CY) FWID 01-f71        28517
.1 5026 [Tmr Svc] Wi-Fi Connected to AP. Creating tasks which use network...
2 5026 [Tmr Svc] IP Address acquired 172.24.172.118
3 6745 [Tmr Svc] Write certificate...
4 7573 [iot_threa] [INFO ][DEMO][lu] ---------STARTING DEMO---------
5 7575 [iot_threa] [INFO ][INIT][lu] SDK successfully initialized.
.6 11401 [iot_threa] [INFO ][DEMO][lu] Successfully initialized the demo. Network type f        or the demo:7 11401 [iot_threa] [INFO ][MQTT][lu] MQTT library successfully initialized.
8 11401 [iot_threa] [INFO ][DEMO][lu] MQTT demo client identifier is Cypress (length 7).
.9 16009 [iot_threa] [INFO ][MQTT][lu] Establishing new MQTT connection.
10 16011 [iot_threa] [INFO ][MQTT][lu] Anonymous metrics (SDK language, SDK version) wil        l be provid11 16012 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, CONNECT op        eration 0x800c168) Wai12 16296 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778,        CONNECT operation 0x800c168) Wai13 16296 [iot_threa] [INFO ][MQTT][lu] New MQTT connect        ion 0x800d7d4 established.
14 16298 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) SUBSCRIBE operation s        cheduled.
15 16298 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, SUBSCRIBE operation 0        x800c168) W16 16581 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, SUBSCRIBE        operation 0x800c168) W17 16581 [iot_threa] [INFO ][DEMO][lu] All demo topic filter subsc        riptions accepted.
18 16581 [iot_threa] [INFO ][DEMO][lu] Publishing messages 0 to 1.
19 16583 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
20 16585 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
21 16585 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
22 16834 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 0 successfully sent.
23 16860 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde24 16861 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
25 16861 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 0 will be sent        .
26 17076 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 1 successfully sent.
27 17106 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde28 17106 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
29 17106 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 1 will be sent        .
30 17108 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
31 17108 [iot_threa] [INFO ][DEMO][lu] Publishing messages 2 to 3.
32 17108 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
33 17110 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
34 17110 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
35 17616 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 2 successfully sent.
36 17617 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 3 successfully sent.
37 17618 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde38 17618 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
39 17618 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 3 will be sent        .
40 17620 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde41 17620 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
42 17620 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 2 will be sent        .
43 17621 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
44 17621 [iot_threa] [INFO ][DEMO][lu] Publishing messages 4 to 5.
45 17621 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
46 17623 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
47 17623 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
48 18153 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 5 successfully sent.
49 18155 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 4 successfully sent.
50 18179 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde51 18179 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
52 18179 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 5 will be sent        .
53 18183 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde54 18183 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
55 18183 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 4 will be sent        .
56 18185 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
57 18185 [iot_threa] [INFO ][DEMO][lu] Publishing messages 6 to 7.
58 18186 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
59 18187 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
60 18187 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
61 18716 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 7 successfully sent.
62 18718 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 6 successfully sent.
63 18743 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde64 18744 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
65 18744 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 7 will be sent        .
66 18745 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde67 18745 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
68 18745 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 6 will be sent        .
69 18747 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
70 18747 [iot_threa] [INFO ][DEMO][lu] Publishing messages 8 to 9.
71 18747 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
72 18749 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
73 18749 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
74 19280 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 8 successfully sent.
75 19282 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 9 successfully sent.
76 19307 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde77 19308 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
78 19308 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 8 will be sent        .
79 19309 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde80 19309 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
81 19309 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 9 will be sent        .
82 19311 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
83 19311 [iot_threa] [INFO ][DEMO][lu] Publishing messages 10 to 11.
84 19311 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
85 19313 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
86 19313 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
87 19841 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 10 successfully sent.
88 19842 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 11 successfully sent.
89 19868 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde90 19869 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
91 19869 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 10 will be sen        t.
92 19870 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotde93 19870 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        0x8012778) MQTT PUBLISH operation queued.
94 19870 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 11 will be sen        t.
95 19872 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
96 19872 [iot_threa] [INFO ][DEMO][lu] Publishing messages 12 to 13.
97 19872 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
98 19874 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operatio        n queued.
99 19874 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
.100 20400 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 12 successfully sent.
101 20401 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 13 successfully sent.
102 20427 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd103 20428 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        104 20428 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 12 will be se        nt.
105 20429 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd106 20429 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        107 20429 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 13 will be se        nt.
108 20431 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
109 20431 [iot_threa] [INFO ][DEMO][lu] Publishing messages 14 to 15.
110 20431 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operati        111 20433 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operati        112 20433 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
113 20962 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 15 successfully sent.
114 20963 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 14 successfully sent.
115 20988 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd116 20988 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        117 20988 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 15 will be se        nt.
118 20990 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd119 20990 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        120 20990 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 14 will be se        nt.
121 20992 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
122 20992 [iot_threa] [INFO ][DEMO][lu] Publishing messages 16 to 17.
123 20992 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operati        124 20994 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operati        125 20994 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
126 21525 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 16 successfully sent.
127 21525 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 17 successfully sent.
128 21550 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd129 21550 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        130 21550 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 16 will be se        nt.
131 21552 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd132 21552 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        133 21552 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 17 will be se        nt.
134 21554 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
135 21554 [iot_threa] [INFO ][DEMO][lu] Publishing messages 18 to 19.
136 21554 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operati        137 21556 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) MQTT PUBLISH operati        138 21556 [iot_threa] [INFO ][DEMO][lu] Waiting for 2 publishes to be received.
139 22081 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 18 successfully sent.
140 22083 [iot_threa] [INFO ][DEMO][lu] MQTT PUBLISH 19 successfully sent.
141 22108 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd142 22108 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        143 22108 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 18 will be se        nt.
144 22110 [iot_threa] [INFO ][DEMO][lu] Incoming PUBLISH received:
Subscription topic filter: iotd145 22110 [iot_threa] [INFO ][MQTT][lu] (MQTT connection        146 22110 [iot_threa] [INFO ][DEMO][lu] Acknowledgment message for PUBLISH 19 will be se        nt.
147 22112 [iot_threa] [INFO ][DEMO][lu] 2 publishes received.
148 22112 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) UNSUBSCRIBE operatio        n scheduled149 22112 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, UNSUBSCRI        BE operation 0x800c168150 22662 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778        , UNSUBSCRIBE operation 0x800c168151 22663 [iot_threa] [INFO ][MQTT][lu] (MQTT connectio        n 0x8012778) Disconnecting connection.
152 22663 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, DISCONNECT operation        0x800c168)153 22663 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778, DISCONNEC        T operation 0x800c168)154 22665 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778        ) Connection disconnected.
155 22668 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) Network connection c        losed.
156 22968 [iot_threa] [INFO ][MQTT][lu] (MQTT connection 0x8012778) Network connection d        estroyed.
157 22968 [iot_threa] [INFO ][MQTT][lu] MQTT library cleanup done.
158 22968 [iot_threa] [INFO ][DEMO][lu] Demo completed successfully.
159 22969 [iot_threa] [INFO ][INIT][lu] SDK cleanup done.
160 22969 [iot_threa] [INFO ][DEMO][lu] -------DEMO FINISHED-------
Hi ChTa_4684556,
Glad your issue is resolved
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
LiDo_2439176
Regarding uint32_t as 'type cannot be resolved' problem. Try Project->C/C++ Index->Rebuild.
Yes, I have tried this but it doesn't work. Restarting the computer seems to do the job. Thanks
