I have installed demo RFCOMM_Serial_Port application on my evaluation board CYBY-483056-EVAL. After downloading program I was able to connect to device from PC. I opened the client control application and connected on WICED HCI port.
But then all the remaining tab controlls are grayed out and disabled.
If you want to use the ClientControl to communicate with the device, there should be HCI interface related code in the application. For example, you can refer to the Audio_Watch demo for CYW20719B2EVB and check the function hci_control_hci_packet_cback().
