I am trying to utilize path 'fragments' as described in Modus Toolbox User Guide V2.3, section 6.2.3 Processing.
I have been unable to get the relative path behavior according to the doc.
Attached is the the table in the picture
Specifically, I want to insert a path fragment into the manifest.loc file, so that Modus treats it as a relative path from the default home path in windows, aka C:/Users/username/.modustoolbox/ as described:
Append the directory in which manifest.loc resides (e.g.,
file:///c/Users/benh/.ModusToolbox/my/manifests/supermanifest.xml)
if I insert a line like this:
"local_manifests/eng/modus_manifest/jk-supermanifest.xml"
The Library manager errors with:
Found C:/Users/John_K/.modustoolbox/manifest.loc
Found user super-manifest(s):
file:///local_manifests/eng/modus_manifest/jk-super-manifest.xml
Processing super-manifest file:///local_manifests/eng/modus_manifest/jk-super-manifest.xml...
file:///local_manifests/eng/modus_manifest/jk-super-manifest.xml doesn't exist
If I modify manifest.loc to use the absolute path to the super manifest the library processes it correctly.
Getting manifests from remote server...
#################################################################################################### 100%
file:///C:/Users/John_K/.modustoolbox/local_manifests/eng/modus_manifest/jk-super-manifest.xml
Processing super-manifest file:///C:/Users/John_K/.modustoolbox/local_manifests/eng/modus_manifest/jk-super-manifest.xml...
ModusToolbox General
Hello @John_K ,
I am able to reproduce this error on my side. I have passed this on to the software team for evaluation. Please use absolute paths as a workaround until then.
Thank you for pointing this out! 🙂
Dheeraj
Hello @John_K ,
Dheeraj
