I cannot login in the Infineon Developer Center Launcher with a firewall LAN. Perhaps it is a proxy issue, but there is no proxy setting in the Infineon Developer Center Launcher.
How do I set up a proxy or what is the workaround ?
Kazu Hayashi
ModusToolbox General
Hello Kazu Hayashi,
It seems not the Developer Center Launcher issue, can you close your firewall and try again? May login is blocked by your LAN firewall.
Hello, I asked an internal developer about this. Here is the response:
this issue might be caused by the firewall or system settings of the client. To be able to perform the authentication the local only port 45210 needs to be allowed to get used by the Launcher to perform an OAuth authentication.
In case this is not working or not allowed by the system, the user can also go to https://softwaretools.infineon.com/welcome and download tools directly.
