Compiling HelloWorld application get following compile error:
Looked at library:
Noticed CY8CKIT-064B0S2-4343W is selected. Is that normal?
Should I unselect it?
If not how do I fix cysecuretools error?
ispn:40035:1:0
ispn:40047:1:0
l1:314:1:0
Deleted Hello World project.
Reloaded Hello World Project.
It compiles and loads just fine.
I must of clicked wrong library
Thanks for sharing the experience, maybe lesson
Hello!
You can change the target board using the 'Active BSP' dropdown selection in the Library Manager. From your screenshot it looked like you had the wrong BSP selected.
Yes,
Update to my response: Wait... wait... thats it!!! I probably did not have it selected 'Active BSP'... Thank you Arvind.
In fact that is the first thing I did. And the library manager removed it.
When I recompiled I still had the same message. "cysecuretools not found".
Anyway I've had no issues since...
To this day... I still don't know how that happened because I am pretty sure I clicked the correct platform.
But... Usually when I have an issue... Its always turned out to be something I did incorrectly... lol.
No worries
BTW, the "cysecuretools" message will get fixed in an upcoming update of this Hello World example (and many others), which adds instructions on how to use it with PSoC 64 Secure boards like the CY8CKIT-064B0S2-4343W.
