Tried to create a basic Empty BTSDK App. This is what I got.
Summary:
BSP: CYBT-333047-EVAL
Template Application(s): Empty BTSDK App
Note: The 'Empty BTSDK App' application template(s) use(s) the ModusToolbox 2.x format. The application(s) do(es) not support 3.x features. See KBA236134 for instructions on how to migrate the application(s) for 3.x content compatibility.
Application(s) Root Path: D:/Jims_Folders
Press "Create" to create the selected application(s).
Collecting application data...
Info: The following entered on the command line will create the exact same project as that created with the GUI tool:
C:/Infineon/Tools/ModusToolbox/tools_3.0/project-creator/project-creator-cli.exe --board-id CYBT-333047-EVAL --board-uri https://github.com/Infineon/TARGET_CYBT-333047-EVAL --board-commit latest-v3.X --app-id mtb-example-btsdk-empty --app-uri https://github.com/cypresssemiconductorco/mtb-example-btsdk-empty --app-commit latest-v4.X --cypress-tools C:/Infineon/Tools/ModusToolbox/tools_3.0 --target-dir D:/Jims_Folders --user-app-name Empty_BTSDK_App_2 --use-modus-shell
Starting application creation for 'D:/Jims_Folders/Empty_BTSDK_App_2'.
Acquiring the application source 'https://github.com/cypresssemiconductorco/mtb-example-btsdk-empty'.
Acquired application source successfully.
Loading the application.
Application load failed.
ERROR:Application creation failed.
ERROR:makefile:169: *** Unable to find any of the available CY_TOOLS_PATHS -- C:\Infineon\Tools\ModusToolbox\tools_3.0. Stop.
Skipping export of the "Empty_BTSDK_App_2" application to Eclipse IDE for ModusToolbox™.
2 error(s), 0 warning(s)
Summary:
ERROR:Failed to create and export "Empty_BTSDK_App_2" application.
I have a custom board with an AIROC CYBLE-333047 and I need to make things work.
I'm sure something is set up wrong. I have set up several environment variables that I saw on some blogs, but........
Now what??????
Hi again, I think the problem might be you're using back slashes in your variables. Need to use forward slashes. Also, I would put cache, global, and offline all in C:/.modustoolbox/, but that's just me:
CY_GETLIBS_CACHE_PATH = C:/.modusbox/cache
CY_GETLIBS_GLOBAL_PATH = C:/.modustoolbox/global
CY_GETLIBS_OFFLINE_PATH = C:/.modustoolbox/offline
CY_TOOLS_PATHS = C:/Infineon/Tools/ModusToolbox/tools_3.0
Hello, This is the error I think is your problem:
Where did you install ModusToolbox tools package? If not c:\Users\<user-id>\ModusToolbox\ then did you set up a system variable to specify the tools_3.0 folder location? Refer to the installation guide for more details:
This is what happened next;
Summary:
BSP: CYBLE-333074-EVAL-M2B
Template Application(s): LE Alert Notification Service, LE Battery Service, LE Heart Rate Service, LE Hello Client, LE Hello Sensor
Note: The 'LE Alert Notification Service, LE Battery Service, LE Heart Rate Service, LE Hello Client, LE Hello Sensor' application template(s) use(s) the ModusToolbox 2.x format. The application(s) do(es) not support 3.x features. See KBA236134 for instructions on how to migrate the application(s) for 3.x content compatibility.
C:/Infineon/Tools/ModusToolbox/tools_3.0/project-creator/project-creator-cli.exe --board-id CYBLE-333074-EVAL-M2B --board-uri https://github.com/Infineon/TARGET_CYBLE-333074-EVAL-M2B --board-commit latest-v3.X --app-id mtb-example-btsdk-ble-alert-server --app-uri https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-alert-server --app-commit latest-v4.X --cypress-tools C:/Infineon/Tools/ModusToolbox/tools_3.0 --target-dir D:/Jims_Folders --user-app-name LE_Alert_Notification_Service_5 --use-modus-shell
Starting application creation for 'D:/Jims_Folders/LE_Alert_Notification_Service_5'.
Acquiring the application source 'https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-alert-server'.
ERROR:makefile:166: *** Unable to find any of the available CY_TOOLS_PATHS -- C:\Infineon\Tools\ModusToolbox\tools_3.0. Stop.
Skipping export of the "LE_Alert_Notification_Service_5" application to Eclipse IDE for ModusToolbox™.
C:/Infineon/Tools/ModusToolbox/tools_3.0/project-creator/project-creator-cli.exe --board-id CYBLE-333074-EVAL-M2B --board-uri https://github.com/Infineon/TARGET_CYBLE-333074-EVAL-M2B --board-commit latest-v3.X --app-id mtb-example-btsdk-ble-battery-server --app-uri https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-battery-server --app-commit latest-v4.X --cypress-tools C:/Infineon/Tools/ModusToolbox/tools_3.0 --target-dir D:/Jims_Folders --user-app-name LE_Battery_Service_5 --use-modus-shell
Starting application creation for 'D:/Jims_Folders/LE_Battery_Service_5'.
Acquiring the application source 'https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-battery-server'.
ERROR:makefile:207: *** Unable to find any of the available CY_TOOLS_PATHS -- C:\Infineon\Tools\ModusToolbox\tools_3.0. Stop.
Skipping export of the "LE_Battery_Service_5" application to Eclipse IDE for ModusToolbox™.
C:/Infineon/Tools/ModusToolbox/tools_3.0/project-creator/project-creator-cli.exe --board-id CYBLE-333074-EVAL-M2B --board-uri https://github.com/Infineon/TARGET_CYBLE-333074-EVAL-M2B --board-commit latest-v3.X --app-id mtb-example-btsdk-ble-heart-rate-server --app-uri https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-heart-rate-server --app-commit latest-v4.X --cypress-tools C:/Infineon/Tools/ModusToolbox/tools_3.0 --target-dir D:/Jims_Folders --user-app-name LE_Heart_Rate_Service_4 --use-modus-shell
Starting application creation for 'D:/Jims_Folders/LE_Heart_Rate_Service_4'.
Acquiring the application source 'https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-heart-rate-server'.
ERROR:makefile:161: *** Unable to find any of the available CY_TOOLS_PATHS -- C:\Infineon\Tools\ModusToolbox\tools_3.0. Stop.
Skipping export of the "LE_Heart_Rate_Service_4" application to Eclipse IDE for ModusToolbox™.
C:/Infineon/Tools/ModusToolbox/tools_3.0/project-creator/project-creator-cli.exe --board-id CYBLE-333074-EVAL-M2B --board-uri https://github.com/Infineon/TARGET_CYBLE-333074-EVAL-M2B --board-commit latest-v3.X --app-id mtb-example-btsdk-ble-hello-client --app-uri https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-hello-client --app-commit latest-v4.X --cypress-tools C:/Infineon/Tools/ModusToolbox/tools_3.0 --target-dir D:/Jims_Folders --user-app-name LE_Hello_Client --use-modus-shell
Starting application creation for 'D:/Jims_Folders/LE_Hello_Client'.
Acquiring the application source 'https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-hello-client'.
ERROR:makefile:165: *** Unable to find any of the available CY_TOOLS_PATHS -- C:\Infineon\Tools\ModusToolbox\tools_3.0. Stop.
Skipping export of the "LE_Hello_Client" application to Eclipse IDE for ModusToolbox™.
C:/Infineon/Tools/ModusToolbox/tools_3.0/project-creator/project-creator-cli.exe --board-id CYBLE-333074-EVAL-M2B --board-uri https://github.com/Infineon/TARGET_CYBLE-333074-EVAL-M2B --board-commit latest-v3.X --app-id mtb-example-btsdk-ble-hello-sensor --app-uri https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-hello-sensor --app-commit latest-v4.X --cypress-tools C:/Infineon/Tools/ModusToolbox/tools_3.0 --target-dir D:/Jims_Folders --user-app-name LE_Hello_Sensor_6 --use-modus-shell
Starting application creation for 'D:/Jims_Folders/LE_Hello_Sensor_6'.
Acquiring the application source 'https://github.com/cypresssemiconductorco/mtb-example-btsdk-ble-hello-sensor'.
ERROR:makefile:163: *** Unable to find any of the available CY_TOOLS_PATHS -- C:\Infineon\Tools\ModusToolbox\tools_3.0. Stop.
Skipping export of the "LE_Hello_Sensor_6" application to Eclipse IDE for ModusToolbox™.
10 error(s), 0 warning(s)
Summary:
ERROR:Failed to create and export "LE_Alert_Notification_Service_5" application.
ERROR:Failed to create and export "LE_Battery_Service_5" application.
ERROR:Failed to create and export "LE_Heart_Rate_Service_4" application.
ERROR:Failed to create and export "LE_Hello_Client" application.
ERROR:Failed to create and export "LE_Hello_Sensor_6" application.
Environment Variables are set;
CY_GETLIBS_CACHE_PATH = C:\.modusbox\cache
CY_GETLIBS_GLOBAL_PATH = C:\.global
CY_GETLIBS_OFFLINE_PATH = C:\offline
CY_TOOLS_PATHS = C:\Infineon\Tools\ModusToolbox\tools_3.0
Forward slashes worked. Wondering why, but....... Also cleaned up directory names. The labels I had were better than the modbus ones I started with.
The forward slashes are required because they are being read by the Make system in the Cygwin environment. It's part of the reason that you can use ModusToolbox applications in Linux, macOS, and Windows interchangeably.
