hi,
I am trying to use Audio_Headset_and_Speaker and CYW20721B2EVK-02 on modustoolbox 3.x.
But got error "CYW920721B2EVK-02.mk:138: *** Failed to parse BTP variables from file: /platforms/20721_OCF.btp" after "make getlibs" command.
Any comment to fix this error? Which "make variables" and make file should be edit??
Austin
Hi @austin_h ,
The B2 board for 20721 is no longer supported in MTB. Kindly upgrade to the newer M2 board. (20721M2EVK-01).
Thanks and regards,
Advait Kulkarni
Hi @austin_h ,
Thanks and regards,
Advait Kulkarni
Hi Advait:
Thanks for sharing. I found the other way to make that EVK work.
Austin
