I've experimented with reading analog signal using CY8CPROTO-062-4343W SAR ADC from built-in thermistor. It is using pins P10_0, P10_1, P10_2, P10_3. Pins P10_4 and P10_5 are used by PDM. I can't find headers for P10_6 and P10_7.
Which headers/pins on CY8CPROTO-062-4343W should I use so I can read signal from external source and measure this signal using SAR ADC?
Sergey
I should remove R36 and R37 to disconnect thermistor output from P10_1 and P10_2 respectively. I've found this information in the CY8CPROTO-062-4343W PSoC 6 Wi-Fi BT Prototyping Kit Guide.
