Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
jotoffel
I have updated my new uIO stick according to the manual by executing "UpdateBSL.cmd".
Now the stick is not recognised as HDI device any more.
Unfortunately I did not make a screenshot of the console after the update, the only thing I remember was, that after programming it said to press "any key" to continue and then the console closed.
On the device it self there is only the 5V and 3.3V LED green – no other LEDS are on.
I guess fw update might faild and the device is no dead. Is there a change to program the uIO stick with j-link or Lauterbach?
BR
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi All,
The uIO stick was getting corrupt due to uploading the new firmware. It will be fixed soon.
Please send the uIO sticks to the following address to fix the corrupted uIO stick:
Address:
Attn: Mr Bhushan Joshi
RMA: UIO Reflash
Hitex GmbH
Greschbachstr. 12
76229 Karlsruhe / Germany
Hitex will fix these uIO sticks and send them back directly.
Please let us know if you have any issues.
Thank you
Best Regards
Raj Chaudhari
jcfjcf45200
5 replies posted 5 sign-ins First reply posted
Hello Jotoffel,
I've the same problem after uptaded my µIO-stick with the script. I think the problem comes from the firmware  supplied in the package, the size is only 17 KB. I updated an other µIO-Stick with Config Wizzar, v2.2.2, the size of this firmware is 222 KB.
We tried to flash directly the µcontroller of the µIO-Stick with a J-flash prob, but it is not recognized by J-Flash.
Actually, no solution find.
Raj_C
Hi @jotoffel,
Could you please confirm if you have programmed the latest version of the BSL firmware? (Please find it in the attachment)
If the programming is successful it will display like the following:
Please let us know if you followed above mentioned points.
Thank you
Best Regards
Raj Chaudhari
jcfjcf45200
I think it is not the last version, the release date is 2018, I updated my µIO-stick with the version supplied by Config Wizard, V2.2.2.
jotoffel
@jcfjcf45200
Thank you for your answer. Yes, it seems like the same issue. Unfortunatally I only have one stick available, so I cannot try with Config Wizzar.
@Raj_C
Thank you for your answer. I run the script which came with the BSL-TOOLS package. There it says FW ‘bsl_1.1.867.fw’. I guess I had the same output as you showing in your console output.
jcfjcf45200
I had a meet with Infineon this morning, normally  the procedure described in the µIO-stick manual must work, the guy tell me he applied this procedure in his office, it works fine, but we applied in the procedure with my PC and my µIO-stick, and we had the same problem, now it is bricked. He must see with his colleague why it is happened and find a solution to unbrick the µIO-stick. If a solution is found, I will post the solution of course.
Stab
First reply posted Welcome!
Hi, I have the same issue. I also used the firmware from the BSL Tool package.
Looking forward to a solution.
Raj_C
We have forwarded this issue to our internal team, who are evaluating this query.
We will provide a response as soon as we get an update from our internal team.
Thank you for your patience.
Thanks and Regards,
Raj Chaudhari
jotoffel
Hello Raj,
Thanks for the update. Do you might know a way to avoid this problem with a new uIO stick? I have ordered two new ones and do not want to lock them as well.
BR
BR
Raj_C
Hi All,
Address:
RMA: UIO Reflash
Hitex GmbH
Greschbachstr. 12
Thank you
Best Regards
Raj Chaudhari
Ok, thanks a lot. I will send my µIo-stick to Hitex.
