MOTIX™ MCU
User22901
New Contributor II
I'm new to MOTIX MCUs and try to get up and running with a
TLE9879-2QXA40 on the TLE987x EvalBoard.
I would need the example TLE9879_BLDC_FOC_SENSORLESS "Driving a BLDC
motor with sensorless FOC" but I'm forced to use a
TLE9879-2QXA40. Strangely for this MCU there is only one example (and
not the one I need):
5266.attach
but most of the other controllers in the same
family have got a lot more examples, more than 40:
5267.attach
I can't find any explanation in the data sheets.
Is the a problem with the TLE9879-2QXA40 so that these examples don't
work?
Volker
Moz
Hi Volker,
Thanks for your question.
The examples provided in the software pack are valid for all the variants of the MOTIX™ MCU TLE987x.
TLE9879-2QXA40 has a sigma-delta ADC for which an additional example has been prepared.
The other examples can be copied and the device vaiant can be changed to use them for any veriant.
The steps of how to change a variant are described in the Books->SDK Help Section of Keil uVision
Moz
Moz
Hi Volker,
Moz
