- Email to a Friend
I try to add the example code of DMA_UART_TTY_EXAMPLE_TLE987X to my
project.
After setting the DMA options:
the header dma_defines.h is correctly generated.
But I get following errors:
compiling Main.c...
app\Main.c(69): error: #20: identifier "DMA_CH12_NoOfTrans" is undefined
char uart_tx_data[DMA_CH12_NoOfTrans] = "Hello World!\r\n";
app\Main.c(85): warning: #223-D: function "DMA_Master_En" declared implicitly
DMA_Master_En();
app\Main.c(187): warning: #223-D: function "DMA_Reset_Channel" declared implicitly
DMA_Reset_Channel(DMA_CH12, DMA_CH12_NoOfTrans);
app\Main.c(187): error: #20: identifier "DMA_CH12" is undefined
-> dma_defines.h is not included.
and really there is no #define RTE_DEVICE_SDK_DMA in RTE_Components.h.
But I should not edit RTE_Components.h directly. How can I add
RTE_DEVICE_SDK_DMA, I can't find any setting in Keil uvison.
Volker
My RTE_Components.h:
* Auto generated Run-Time-Environment Configuration File
* *** Do not modify ! ***
* Project: 'my_controller'
* Target: 'TLE9879_EvalKit'
#ifndef RTE_COMPONENTS_H
#define RTE_COMPONENTS_H
* Define the Device Header File:
#define CMSIS_device_header "tle987x.h"
/* Infineon::Device:ConfigWizard_v2:2.1.12 */
#define CONFIGWIZARD 2
/* Infineon::Device:SDK:ADC1:0.2.8 */
#define RTE_DEVICE_SDK_ADC1
/* Infineon::Device:SDK:ADC2:0.2.5 */
#define RTE_DEVICE_SDK_ADC2
/* Infineon::Device:SDK:BDRV:0.4.8 */
#define RTE_DEVICE_SDK_BDRV
/* Infineon::Device:SDK:BOOTROM:0.3.0 */
#define RTE_DEVICE_SDK_BROM
/* Infineon::Device:SDK:CCU6:0.3.2 */
#define RTE_DEVICE_SDK_CCU6
/* Infineon::Device:SDK:CSA:0.1.7 */
#define RTE_DEVICE_SDK_CSA
/* Infineon::Device:SDK:GPT12E:0.2.0 */
#define RTE_DEVICE_SDK_GPT12E
/* Infineon::Device:SDK:INT:0.2.2 */
#define RTE_DEVICE_SDK_INT
/* Infineon::Device:SDK:ISR:0.2.8 */
#define RTE_DEVICE_SDK_ISR
/* Infineon::Device:SDK:LIN:0.1.9 */
#define RTE_DEVICE_SDK_LIN
/* Infineon::Device:SDK:MON:0.1.6 */
#define RTE_DEVICE_SDK_MON
/* Infineon::Device:SDK:PMU:0.2.0 */
#define RTE_DEVICE_SDK_PMU
/* Infineon::Device:SDK:PORT:0.5.7 */
#define RTE_DEVICE_SDK_PORT
/* Infineon::Device:SDK:SCU:0.5.4 */
#define RTE_DEVICE_SDK_SCU
/* Infineon::Device:SDK:WDT1:0.3.2 */
#define RTE_DEVICE_SDK_WDT1
#endif /* RTE_COMPONENTS_H */
Embedded Power IC's
- Email to a Friend
Hi Volker,
Thanks for your question.
Can you please check if you have checked the box next to DMA in the Manage Run-Time Environment -> Device -> SDK?
Moz
- Email to a Friend
Hi Volker,
Moz
- Email to a Friend
Thanks Moz, that was exactly the problem!
Have a nice day
Volker
