Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
wang1
Level 4
Level 4
50 questions asked 10 likes given First solution authored
Everybody is good!
I would like to ask, TLE9842-2QX, the power supply voltage of single chip is 12V, then I set the GPIO port as out-of-PP mode, what is the output voltage V? There is no content about GPIO port voltage control in the manual.
Thanks!
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @wang1,
For the chip's voltage rating, please refer to the Electrical characteristics section 28 of the TLE9842-2QX datasheet.
This section includes all the device voltage ratings-related information. For your reference, the GPIO voltage for the TLE9842-2QX is given in the following table (highlighted) from the datasheet.
Please, let us know if you need further clarification.
Thank you
Best Regards
Raj Chaudhari
Raj_C
Hi @wang1,
Thank you
Best Regards
Raj Chaudhari
