Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
xjs286268
25 sign-ins 5 replies posted First like received
The question description of IAR software to develop TLE9879 chip
Question:
When I use IAR software to import Infineon pack, l find that the pack of Infineon can not be imported, please tell me which kind of Infineon pack l should to import to develop TLE9879.if you can give me an example, l will very appreciate you.
IAR version:8.32.1
In IAR software Release Notes,l check the device support,ensure that 8.32 version support TLE9879.
Infineon pack :Version 1.6.0(2022-12-22) and Version 1.5.2 can not import success.
Hi   LinGuohui
just now l have solved the problem,l import the CMSIS pack,and than the project is normal,thank you for your help.
LinGuohui
500 replies posted 50 likes received 250 solutions authored
Hi @xjs286268
It should be issue with the IAR version, My IAR import these packs without any problems.
xjs286268
Hi : LinGuohui
Thank you for you response first,l have buy the license of IAR version of 8.32.1,so l want to use 8.32.1 to add Infineon pack.The IAR  version of 9.32.1 l have test, the function is ok,the this version l do not buy the license. so l must to find the way to search the answer about how to use 8.32.1 to develop TLE9879.
LinGuohui
Maybe you can connect IAR for support.
Below is the response:
LinGuohui
You can try installing the old version of TLE987x software package.
https://www.keil.arm.com/packs/tle987x_dfp-infineon/versions/
Hi Linguohui:
when l use the pack of Infineon  Version 1.2.4 to import to the IAR,the error is occur as below:
when the Infineon  version 1.24.1 has imported,l  build a new project ,the CMSIS-pack is empty,but when l use IAR 9.32 and Infineon 1.6.0,the CMSIS-PACK is normal.if you have any thinking  or way to help me?
Hi   LinGuohui
