TLe987x Evalboard Counting turns thanks to hall effect sensor
Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
User17857
First like received
Hello Everyone,
I use tle987x with trinamic qbl4208-61-04-013 bldc motor that has hall effect sensor. I want to count the turns that the motor has done. Do you have any suggestion for me ?
kind regards
Murat.
Fiz
First like received 50 replies posted 25 replies posted
Hello Murat,
you will see a hall pulse from every hall sensor every electric revolution.
The motor has 4 pol pairs so it will perform a full mechanical revolution every 4 electric revolution.
So you know for every 4 pulses you have counted your motor has done one turn.
Best,
Fiz
