User19019
Hi Infineon team,
I would like to know if there is a sample code available which is related to UART1.
The sample code should contain the configuration of port registers, UART1 registers, timer registers and also some simple UART transmit and receive functions.
The reason of asking for the sample code is because I'm facing some issues in enabling UART1 on TLE987x. I need to compare my register configurations with the configurations written in the sample code.
Thank you.
User17857
First like received
there are 2 examples related to UART in keil uvision5 if you install tle987 pack on keil uvision5.
