Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
JAYLOU
First solution authored 10 questions asked 50 sign-ins
Hi Infineon,
Is there anyone know how to control the motor speed by adjusting the duty cycle of PWM on PIN LIN?
LinGuohui
500 replies posted 50 likes received 250 solutions authored
Hi @JAYLOU
Refer to TLE987x_UM-UserManual , we can see that the LIN input signal can be connected to TIMER2. Therefore, we can use TIMER2 to capture this signal.
LinGuohui
Hi @JAYLOU
Translation_Bot
Thanks for your reply, can I control the motor speed by configuring “internal LIN Trx”, by sending LIN report to pin 43, i.e. LIN? If I want to control it via PWM, do I want to configure it to P1.2 (T2EX_1)?
Translation_Bot
I'm currently using Timer2_get_capture (); as a speed reference, but I don't feel right.
Translation_Bot
From the LIN diagram above, we can know that the signal sent by the Tle987x LIN comes from the TxD_1 of the UART, that is, the LIN output can only be controlled via UART1. LIN input signals can receive RxD_1, i.e. read data via UART1; they can also receive T2EX of TIMER2. There may be problems with this representation that T2EX is an internal signal connector, not an external Pin. T2EX CAN BE USED AS TIMER2'S TRIGGER SIGNAL AND CAN BE CONFIGURED IN THE CONFIGURATION TOOL.
