Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
syrine
5 questions asked 10 sign-ins First reply posted
Dear infineon team,
I am trying to write and read data from emulated EEPROM but I can't understand the mecanism.
In this application note  https://www.infineon.com/dgdl/Infineon-TLE987x_Data_Flash_Handling-AN-v01_01-EN.pdf?fileId=5546d4626...  , figure 12 provides 3 examples of how the Spare Page Pointer selection is working.
The example code, dowloaded from pack installer "NVM_DATA_FLASH_HANDLING_EXEMPLE_TLE987X" , is trying to write and rewrite only page 0, if we refer to the document we can not write in an occupied page.
Is there an example code for emulated EEPROM?
Viswa
10 likes received 50 solutions authored 100 replies posted
Hi @syrine
The system is working on logical address here, in-fact this particular program reference also takes care of the errors arising due to issues in the MapRAM assignment etc.
In figure12 it explains how the sparepage pointer is used to fill the MapRAM logical table.
Please refer to section 4.4.5 OpenAB of the document to understand about the used page programming.
Best Regards
Viswa
Hi @syrine
Best Regards
