User19528
First like received
In the "BLDC_SENSORLESS_FOC_LIN_EXAMPLE_TLE987X" SW example, in Emo.c the gain of the CSA is computed as follow:
Could you please tell me to what correspond the value of 1.25 and how it is obtained ? give me please more details
Thanks in advance
OpGain = 10.0;
CSA_Set_Gain(0u);
/* 1.25 => 125mV, secured OpAmp differential input voltage range */
x = Emo_Focpar_Cfg.NominalCurrent * Emo_Focpar_Cfg.Rshunt * 10.0;
if (x < 1.25)
OpGain = 10.0;
CSA_Set_Gain(0u);
x = Emo_Focpar_Cfg.NominalCurrent * Emo_Focpar_Cfg.Rshunt * 20.0;
if (x < 1.25)
OpGain = 20.0;
CSA_Set_Gain(1u);
x = Emo_Focpar_Cfg.NominalCurrent * Emo_Focpar_Cfg.Rshunt * 40.0;
if (x < 1.25)
OpGain = 40.0;
CSA_Set_Gain(2u);
x = Emo_Focpar_Cfg.NominalCurrent * Emo_Focpar_Cfg.Rshunt * 60.0;
if (x < 1.25)
OpGain = 60.0;
CSA_Set_Gain(3u);
User17952
You can refer to the the chapter of CSA in Manual,you will find the limitation of CSA differential input voltage is 1.5V.
1.25V is secured OpAmp differential input voltage range .
