TLE9879
Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
小猪
First question asked Welcome!
TLE9879如何实现周期唤醒
LinGuohui
500 replies posted 50 likes received 250 solutions authored
你好,
TLE9879周期唤醒,最简单的做法推荐使用Config Wizard 工具。Config Wizard 的下载使用,请参考:Getting_Started_TLE986x-7x
Config Wizard 中,可以设置唤醒周期时间等
设置完成后,保存配置,重新编译代码即可。
LinGuohui
你好,
