I'm using the TLE9879QXA40 chip. I want to control ON/OFF of VDDEXT pin. (5V/0V)
VDDEXT pin is designed the same as TLE9879 Evalkit.
Can you provide sample code to control this? Or give me a simple answer.
Hi @Jackson_hwang,
For the operation of the VDDEXT, you can refer to the PMU_VDDEXT (TLE9879 EvalKit) Code example on Keil IDE.
This code example demonstrates different operating conditions of VDDEXT. The VDDEXT is initialised using ConfigWizard for this code example.
Alternatively, to enable (5V) or disable (0V) VDDEXT pin you can use following Line of code:
PMU->VDDEXT_CTRL.bit.ENABLE = 1; (Enables)
PMU->VDDEXT_CTRL.bit.ENABLE = 0; (Disables)
For further Information Please refer to the section 5.3.6.2 VDDEXT Control Register of the TLE987x User Manual.
Please let us know if you need further support.
Thank you
Best Regards
Raj Chaudhari
Hi @Jackson_hwang,
Thank you
Best Regards
Raj Chaudhari
