tabster
03:11 AM
- Email to a Friend
I just want to do some tests on speed and how well the code works. Can I connect the 24V to the shield without any changes, even though the motors won't utilize the full 24 volts themselves?
09:28 PM
- Email to a Friend
05:06 AM
- Email to a Friend
Hello @tabster
I assume you are using the BLDC shield TLE9879 board.
I am not sure what you mean by supplying 24V to the shield but the motors will not use 24 Volts, because you will not be able to operate a 12V motor with a 24 V input to the BLDC shield.
Could you please explain how you plan to implement this scheme of operation?
RupakC
tabster
01:38 PM
- Email to a Friend
no, the motor handles 12-36 V. The power supply I have provides 24 volts. i want to use the Arduino shield but it says 12 V on it. this is basically the issue
09:28 PM
- Email to a Friend
