User19019
I'm using TLE9877 MCU. I found that the logic of Port 0.0 (pin 21) was high by default after software reset.
This pin is a SWCLK. I have to set the pin to low manually but this situation has caused the pin to toggle with a very short pulse (3.6ms).
Is it possible to set the logic of the pin to low by default after software reset?
Thank you.
Ramius
5 sign-ins First like received 10 replies posted
Hello
can you please share how you do the configuration of P0.0? In general, are you using the Config Wizard, or doing it directly in the SW?
Ramius
