Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
AmolKoli
Level 4
Level 4
First solution authored 10 questions asked 50 sign-ins
Hello Team,
We are driving a DC motor using TLE986x and FET bridge combo.
Have used the sample code for LIN and DC motor drive as our base.
Its observed that the PWM duty output is inverted, and the Phase outputs remain high during passive state.
We need to configure non-inverted duty and passive low for the drive output.
Could you please help with the configuration.
Below is code snip for our existing control:
void BDRVupdateConductionState(unsigned char gu8_cstate)
switch (gu8_cstate)
case PWM_CW:
// current dir on eval board : phase A to B on CW command
// BDRVOUTC = 0b00001100;
// BDRVOUTB = 0b00001000;
BDRV_Set_Bridge(Ch_PWM, Ch_PWM, Ch_En, Ch_On);
break;
case PWM_CCW:
// current dir on eval board : phase B to A on CCW command
// BDRVOUTC = 0b00000011;
// BDRVOUTB = 0b00000010;
BDRV_Set_Bridge(Ch_En, Ch_On, Ch_PWM, Ch_PWM);
break;
case PWM_OFF:
// all 4 BDRV channels OFF
// BDRVOUTC = 0b00001111; // all 4 are software controlled
// BDRVOUTB = 0b00000000; // force inactive state on all 4
BDRV_Set_Bridge(Ch_Off, Ch_Off, Ch_Off, Ch_Off);
break;
case PWM_LOW_ON:
// low side ON, high side OFF
// BDRVOUTB = 0b00001010; // force active state on low side
BDRV_Set_Bridge(Ch_En, Ch_En, Ch_En, Ch_En); //TODO Amol - check brake operation(now configured as per test results)
break;
default:
break;
Passive state configuration :
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @AmolKoli,
If you want to match the compare value set in the ConfigWizard with the High state then please change the state of the passive to High as shown below:
Please let me know if you have further questions.
Thank you
Best Regards
Raj Chaudhari
Raj_C
Hi @AmolKoli,
Thank you
Best Regards
Raj Chaudhari
AmolKoli
Level 4
Level 4
Hello @Raj_C ,
This worked for me.
In addition I had to make some changes in the BDRV channel drive pattern to match the new Phase state to get expected Phase duty w/f.
like BDRV_Set_Bridge(Ch_PWM, Ch_PWM, Ch_En, Ch_On)  Change> BDRV_Set_Bridge(Ch_On, Ch_En, Ch_PWM, Ch_PWM);
