公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
rcding
First like received First question asked Welcome!
We could not find any demo IAR projects for MCUTLE9869, TLE9883 or TLE9893 when developing new products. Anyway if we can find the correct the startup_tle98xx.s code which could also help.
Does any one know where to find the  IAR TLE98xx demo project or IAR startup_98xx.s code file?
1 解答
LinGuohui
500 replies posted 50 likes received 250 solutions authored
Hello @rcding
For the development of MOTIX MCU products, we recommend using Keil MDK. But it can also be developed using IAR.
First, you should download the software packs in Arm Keil webset.
TLE988x_9x_DFP
TLE986x_DFP
For Keil MDK, after install the pack , you can copy the sample code .
For IAR,you can also use these packs :
For more information, You can refer to this Getting_Started
在原帖中查看解决方案
0 点赞
1 回复
LinGuohui
Hello @rcding
TLE988x_9x_DFP
TLE986x_DFP
0 点赞
