- Email to a Friend
I tryed switch to Normal mode by Usem manual, but MCU not work and reset.
How return MCU to Normal mode after STOP?
Best regards, Vladimir.
- Email to a Friend
sorry for the late response here.
Can you please share the code, where you go to Stop Mode and go back to Normal (Active) Mode?
Ramius
- Email to a Friend
Hi, Ramius.
I work in uVision and tell about software pack in uVision.
In pack 1.4.4 and scu.c\h version 0.3.8 I enter to stop mode like this and all work good:
for(idx = 0; idx < 4; idx++)
SCU_EnterStopMode();
vTaskDelay(1);
PMU_Clear_Reset_Status();
In pack 1.4.6 and scu.c\h version 0.5.2 after Stop MCU work not correct. Looks like PLL not started and MCU work on some default oscilator. I try restart PLL after STOP mode like this:
vTaskDelay(1);
}Field_Mod8(&SCU->NMICON.reg, (uint8)SCU_NMICON_NMIPLL_Pos, (uint8)SCU_NMICON_NMIPLL_Msk, 0);
SCU->PLL_CON.bit.VCOBYP = 1;
SCU->PLL_CON.bit.OSCDISC = 1;
SCU->OSC_CON.bit.OSCTRIM_8 = 1;
idx = SCU->OSC_CON.reg;
idx |= (1<<5);
SCU->OSC_CON.reg = idx;
SCU->PLL_CON.bit.OSCDISC = 0;
SCU->PLL_CON.bit.RESLD = 1;
while(0 == SCU->PLL_CON.bit.LOCK)
SCU->PLL_CON.bit.VCOBYP = 0;
Field_Mod8(&SCU->NMICON.reg, (uint8)SCU_NMICON_NMIPLL_Pos, (uint8)SCU_NMICON_NMIPLL_Msk, 1);
But it not work. Now I use scu.c\h version 0.3.8 in my code
