Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
User16111
I want to communicate via SSC between the TLE9879 EvalKit and an angle sensor, the TLE5012B (max 8Mbit/s SSC).
I tried and the TLE9879 (Master) cannot received the data from TLE5012B (Slave) at 10Mbaud. The Master cannot receive the data from the Slave because of a Phase Error.
Could you please tell me why the Phase Error is reported and how to fix it?
pestadieu
Please find below an example for a 10 Mbaud connection via SSC using two TLE9879 EvalKit:
Especially at higher baud rates, it is necessary to ensure a proper initialization, otherwise wrong data can be latched and complete communication is disturbed.
Kind regards
