Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
I have been trying to implement LIN communication for the microcontroller and evaluation board mentioned in the title and have been having problem with the Break/Synch Field Detection logic. I have tried using the supplied sample code for LIN_Master and LIN_Slave but to no avail. The break detection works but the flag for ERRSYN triggers right after the break field ends.
Please advice.
Managed to solved the LIN communication handling by removing all the init() from the sample code. Also managed to get LIN handling done with self made algorithm.
Hello, you can share how you solved the problem? I am in a similar situation. Thank you
Mc-Key
Welcome!
just to let you know...
In the meantime, the LIN example codes are fixed.
There are several LIN LLD example projects included to the µVision Keil 5 packfile.
For more information visit:
http://www.infineon.com/tle987x
M.K.
Please share the LIN code. I tried the LIN Slave example from µVision Keil 5 pack file. But it is not working. Your code might be helpful.
User15455
10 sign-ins 5 sign-ins 10 replies posted
Hi Sir,
I can only receive a demand from master using LIN_SLAVE_EXAMPLE_TLE987x_LIN_Slave.
User15455
Hi Keviinx,
Have you sloved this issue. I can only receive a demand after power on.
Lykaon
First like received
Hi Peter,
did you try out the latest examples from our pack files?
User15455
Hi Sir,
I got demo code from Keil. I don't think it is latest examples. Could you please send me a link? Thanks
Main Version:
* Revision: 1.0 *
* Responsible: B. Roegl *
* Creation date: 18/02/2014 *
* Last Modtime: 18/02/2014 *
Linmain.c Version.
V0.1.0: 2014-05-20, DM: Initial version
Lykaon
First like received
I was referring to that version:
https://www.keil.com/dd2/pack/
3195.attach
