MOTIX™ MCU Forum Discussions
I was using the JLINK debugger for Debugging and flashing in the TLE987x board. Now, the debugger is not working. Is there any alternate debugger that can be used instead of JLINK.
It is little urgent scenario. Please help out soon.
cwunder
25 likes received 25 solutions authored 100 sign-ins
You should be able to google for a CMSIS-DAP Debugger and use this. If you are using Keil then you can change from JLINK to CMSIS-DAP Debugger in the debug dialog. Generally you can use any of the other silicon vendors for this cheap solution.
Mc-Key
Welcome!
here are some additional options.
These SWD Debug interfaces are tested with all Infineon Embedded Power devices.
J-Link Debugger:
https://www.segger.com/products/debug-probes/j-link/
ULink SWD Debug Interfaces:
http://www2.keil.com/mdk5/ulink
Infineon XMC Link:
https://www.infineon.com/cms/de/product/evaluation-boards/kit_xmc_link_segger_v1/
M.K.
