Webinar: Integrated solutions for smaller, simpler low-voltage motor control design.
Join the webinar to experience!
SamarpitKarar
First question asked First reply posted Welcome!
Please guide us how to make the connections (3 Hall sensor wires - Blue, White, Green) of the motor(DB59M024035-A) with Arduino Uno through the motor shield (Infineon BLDC shield with TLE9879QXA40).
Sahil_K
First like given 100 solutions authored 250 sign-ins
Hi @SamarpitKarar ,
You can try changing the hall sensor cables( BLUE(H1),GREEN(H2), WHITE(H3)) with respect to the phase excitation, You will be able to change this by interchanging any two hall sensor outputs  H2-> H3 or H3->H1 or H1->H2 ) and then try starting the motor by start command.
Note: Sometimes HALL input requires an external Pullup.
Please let us know if you have further queries.
Thank you
Best Regards
Sahil Kumar
Sahil_K
Hi @SamarpitKarar ,
Thank you
Best Regards
Sahil Kumar
Sahil_K
Hi @SamarpitKarar ,
Please let us know if your current issue is resolved and have any further queries.
Thank you
Best Regards
Sahil Kumar
